Hello all. I am wondering if anyone has any advice or testing ideas for me on my pool pump. I have a 5 year old in-ground vinyl-liner pool with a 3/4 hp Hayward Superpump. Haven't had any issues with the pump in the past five years. But when attempting to start up the pump for the first time this year, it immediately trips the GFCI breaker (in the panel in basement). It's been a wet spring (mostly snow), but the motor appears to be dry inside and out. I switched the wiring at the breaker panel to test it on a different gfci breaker (used for the hot tub) and it immediately tripped that one also. When I disconnect the wiring at the motor, it does not trip the breaker. So, I thought I would further test the motor by disconnecting the wiring and hooking up my own plug (and switching it over to 115V instead of 230V). When I plugged it in to any of the GFCI outlets on the outside of my house, it immediately tripped again. So, I took the motor inside and plugged it in to a non-GFCI outlet and it runs perfectly.
I guess my question is, does this mean the motor itself needs replacing, or is there something else I'm missing that could cause it to work again on the GFCI circuits?
