It seems to be quite the task but my new heater is almost installed, it is plumbed in, propane connected, all I need is electrical. The manual seems very brief on this, as it is a propane heater my understanding is it takes (as delivered) 240/220, there are three connectors under the hatch, two hot and a neutral, there looks to be a separate ground connector.
I have some 12/3 cable and flexible conduit, my plan is to tab off the switch for the pump, run through the conduit to the heater. I am assuming that once I open the switch there will be two switched hot wires coming through a two pole switch then a neutral and ground. So I splice in to each one on the pump side, run my conduit, attach to L1, L2, N, and Ground and I'm good to go - right?
When I was buying the cable there was some debate with the home depot associates about what is needed for "220/240", as I understand it the current draw is very low (less than an amp) and it is essentially two 110v hot wires not one 220v - as such the 12/3 should be fine - am I correct?
I'd appreciate some validation before I start
Thanks in advance,
Chris.
Thanks in advance,
Chris.
