Hi all,
Our pool inlet piping seems to have been leaking, and ended up starving our pump and getting it good and hot, making the inlet and outlet connections particularly loose.
The liberal use of hose clamps worries me - especially on the outlet side - but this is the way the plumbing was when we bought the house. Pictured, you can see the hard piped arrangement that feeds the heat exchanger that heats the pool water.
At this point I'm leaning towards hard piping in and out of the pump, with unions - any suggestions on routing, unions, etc? There isn't a ton of space, and as you can see as oriented the pump can't have 5x diameter length straight shot into it.
Thanks for the help!
