Newbie to TFP. Glad I found it during a search for antenna replacement for my iAqualink IQ900 transceiver. Saved me a few hundred bucks already. I have an inground freshwater gunnite pool in Spring TX (north of Houston). 19,000 gallons, with three scuppers, two gushers and two Grand Effects firebowls. Circular spa as well. It has an ozonator, but I don't think it is doing much good.
- CV 4-Cartridge Filter
- 250K BTU Pentair Heater
- Jandy Watercolor lights (2 in pool, 1 in spa)
- 3 Jandy E pumps variable speed
- Nature II Fusion with Chlorine feeder
Spa Fountain
Main issues that I've faced:
Replacing motherboard on iAqualink system after lightning strike and having to install all of the equipment in the program.
Algae, algae, algae...
Rising cost of chemicals; the builder used borate buffer, which I've been supplementing each year.
Filter cleaning maintenance
Replacing antenna on iAqualink transceiver
Adjusting the overflow valve - it was running continuously for a while before I noticed it
Cleaning up scale on the tiles
Keeping the firebowls running - the fire will often go out after 30 min of run time - I don't know if this is due to heat or ?? Hope to find out on this forum
Spa Fountain
