How quick can green water clear up? I’m trying to avoid draining and refilling again. Yes, I have a tiny pool but a couple ounces of bleach or other chemicals is still cheaper than a thousand gallons of water.
4 or 5 days ago I slammed the pool and then figured out it could’ve just been pollen I was seeing on the bottom of the pool although the CC was 1.0 at that time. Every since, the CC has been 0.5 or less. I never really completed the OCLT but figure since CC is 0.5 or less that I’m good. The pollen or algae is only on the bottom of the pool, so I guess it’s pollen. I didn’t vacuum for a couple days but started back yesterday. When I first went out the water looked clear but the bottom of the pool was green. As I vacuumed, the bottom of the pool would instantly turn clear but nearby pollen would get stirred up into a cloud of stuff. Once I finished vacuuming, the floor was clean but the water was green so I let the pump run all night. It’s a 1,000 gph pump on a 1,000 gallon pool and cartridge filters are suppose to be good according to this site. The filter cartridge was a little dirty but I didn’t want to put a new one in until I had cleaned out some of this mess.
This morning I woke up and the water was still a little green and the bottom of the pool was a little green, so I vacuumed again and then drained nearly a third of the water out and started filling the pool back up. Once the water level was an inch above the inlet screen, I turned the pump back on and continued to fill the pool up.
Now it’s full again and still green. Not as green but still green.
Test results:
5 days ago: TA 130, CH 150, pH 7.5, FC 8.0 (coming off a SLAM) CC 0.5
Monday: 7.8 pH, 4 FC, 32 CYA, CC <0.5 (floor of pool green but water clear)(prior to vacuum)
Yesterday: 7.2pH, 5 FC, <0.5 CC (green water)
Questions:
Algae or pollen? (I think I know the answer but would like confirmation)
Anyway to clear up in a couple hours without draining pool?
Should I be vacuuming to waste? (I’ve never done that but saw mention of it today somewhere on this forum.)
Any and all advice welcome, thanks in advance.
Happy 4th !!
Test results:
Questions:
Happy 4th !!
