Hello,
I'm a newbie pool owner and I've been fighting the algae that's been growing in my pool for the last two months now, and I've just recently discovered this community and was hoping for some help. Two months ago, I went to the local pool supply store and told them my pool was green from algae. They sold me some "green to clean" as well as some shock. I followed their instructions, and while some of the algae did go away, the walls of the pool still had algae growth on it. A week after the treatment, all the algae had returned. I went through this cycle again with the local store, and again, same results - green again after a week or so. I did a little internet research, and that's how I ended up here.
I bought a taylor 2006 testkit and my pool stats are as follows:
FC = 0
CC = 0, (I guess this is 0 since my FC test never changed color)
PH =7.4
TA = 90ppm
CYA = 95
My pool is a 10,000 gallon pool with a Hayward DE filter. plaster surface.
I've read through the SLAM guide and had some basic questions:
1. I am assuming my first step is to lower my CYA. I was planning on just doing this via water changes and testing until my CYA is around 40. Does that sound correct?
2. Should I be adding bleach to my pool while I am trying to lower the CYA, or just wait until my CYA is low enough before I start adding bleach?
3. Can someone explain to me how to read the Chlorine/CYA chart? If my CYA is 40, then I should add enough bleach to get to 5-7 FC? what is the Shock FC column for?
4. How do I know how much bleach to add to increase the FC in my pool? I've looked at the Pool Math calculator, and it tells me that in order to go from 0 FC to 4 FC, I should add 83oz of 6% weight bleach. Is this how much I add for my intial SLAM? Am I to test the water again, adjust my "Now" value and see how much bleach to add for my next time?
Thanks in advance to anyone that responds. I hope that I can be a valuable contributor to this community one day.
FC = 0
PH =7.4
TA = 90ppm
CYA = 95
