I am opening the pool today and majorly regretting letting it get this green. We had such a warm winter at times (with very cold snaps here and there) which I am sure contributed to the green monster. The water temperature is showing 58. But the water is the greenest I've seen in my 8 years of owning the pool! I have not done any testing since it is so green, but I am assuming the CYA is 20.
Question 1: I have the equipment up and running and I started by adding 2 gallons of liquid chlorine. I am tempted to leave the cover partially on and just add chlorine for a day or two, so the sunlight won't add to the algae's stronghold. The downside of leaving the cover on is that I can't brush the pool. What would you do?
Question 2: Do I add the salt now, or wait until the water clears? At what point should I turn on the SWG vs. just using liquid chlorine?
Question 3: How do I prevent this from happening next winter, aside from opening earlier? My water started turning green mid-winter. I don't have a way to circulate the pool water while the equipment is closed down for the winter.
