Hi - I'm so glad I found TFP (thanks to all of you folks!) last week after I decided to stop my pool guy and do it myself (about 4 weeks ago). I got a solar blanket for the pool and he said that he wouldn't service unless I removed the blanket every week before he showed up. To avoid the hassle, I decided to try it myself. I got my water tested by Leslie's (about a week ago) and they told me the CYA levels were high. Since then I did nothing to the pool while I tried to read up on TFP. I've read the basic articles on water chemistry, test kits, pool care etc. and got myself a Taylor K-2006 FAS-DPD kit. I did one test today and feel like I should start fixing the water chemistry. But I have some questions on starting it right. Hope you experts can educate me.
From a test I did this morning, my chlorine is 0 (FC) (which I expect since I've not added any in almost 10 days). pH is high - ~8 (matches the Leslie's). Alkalanity is ~100 (Leslie's said 120). CYA per my test was above 100 (Leslie said 120). CH is 350 per Leslie - I got lazy and didn't check that today. I have some algae growing since the pool has been sitting (covered) at ~80-90F with almost no chlorine. The algae levels are really low though - but definitely more than 0. I removed the cover today and decided to start the TFP method - plan to address CYA first, pH second, them SLAM the pool. Is that the right order and what is the procedure? I've started to drain (partial) the pool to lower CYA. Once the drain (about a 1/3) is complete, I am thinking I should refill, adjust pH and then SLAM. The chlorine I have now (after TFP) is KemTek SodiumHypoChlorite based liquid (~10% strength). Also, any tips on the FC/CC test w/ the Taylor kit? I'm not sure I understand it correctly.
Is the above the recommended approach? Should I be changing what I'm doing. Thanks for any tips!
