I finally opened up my pool for the first time and have gotten great help form users here already!
I’ll eventually be adding a heater (suggestions welcomed!)
Thus is the set up
S8M500 filter
011028 pump
IC60SWG
Anyway, what should I even do to start getting the pool to swimmable water? I was told to ignore the salt for now and just open it up like a typical chlorine pool.
I removed all the algae plants already. Should I just shock it and run the filter 24/7 for a few days, then vacuum, then shock again?
If running it to get the pool cleared asap, what rpm should I be running the filter? And once cleaned, what should it run at?
ill be away for a few days so just want to run it while I’m away and I’ll vacuum when I’m back.
also, a new liner is going in mid July, can’t get anyone else in sooner
Thus is the set up
S8M500 filter
011028 pump
IC60SWG
