- Jul 24, 2017
- 171
- Plaster
- Pentair Intellichlor IC-40
The weather forecast for South Texas is an unprecedented, extended freeze. I have a two pump IntelliFlo system. One pump drives the filter, the second a water feature. When it was installed, automatic freeze protection (pump turns itself on at 38 degrees) was engaged on the filter pump but not on the water feature. It's never been cold enough to matter before, but now it does. If you have an IntelliFlo pump and want to engage this feature, I just dug through the manuals: Menu>Settings>Circuit Func.>Name of Circuit You Want to Change>Freeze:Yes.
Lots of additional helpful advice on TFP, thanks for all of it and good luck to everyone.
