Hi everyone,
I'm having an issue that I hope some more-informed folks can help me with.
I use a Taylor testing kit and last night, the sample read:
I've researched this quite a bit and it may be that I have a yellow algae issue. Does that sound accurate?
If so, can someone please advise how much pool shock I may need and more importantly, what the gallon-equivalent is for liquid chlorine? I buy the big yellow jugs of it from Leslie's Pool Supply (local pool-store chain) so I'm not sure what the exact chemical compound is for the chlorine that is sold in those jugs. However, I have 2 of those full jugs right now and would prefer to use what I have as opposed to buying more chemicals.
Thank you for any help!
- My pool is an inground 15,000 gallon pool located in South Florida.
- It's hot and humid most of the year, it rains most days to some extent and my pool is close to the water, so it almost always has a breeze blowing stuff into the pool.
- It is an outdoor pool that does not have a screen.
- The water itself is clear and I can see right to the deep-end drain cover clearly before I brush the pool.
- Currently, I have to run the filter 12-14 hours per day.
- It is a cartridge filter system with no in-line chlorinator.
- I wash/rinse the filter every day.
- I usually use 1 tablet of chlorine in a floating container each week. 2 tablets seems to send the FC level really high.
- Free Chlorine = 2.0 PPM
- Combined Chlorine = Less that 0.5 PPM
- PH = 7.5
- Alkalinity = 35 PPM
- Cyuranic Acid = 90 PPM
