All,
I am trying to fill up my pool after an acid wash, but the drain plug is allowing ground water to pass through it. It is a horrible design. Here is a picture of the drain and the plug.
View attachment 59665View attachment 59666
You see, the plug is designed so that only the plastic threads are supposed to stop the ground water from coming back up. Huh?!?! What person approved such a design?!?! Someone that works on pools for a living told me that he uses 13 wraps of teflon on the top threads to stop the water. Well, I tried that, and sure, it slows the water down, but you can clearly see water seeping through. My 9 year old daughter told me to try wrapping rubber bands around the top threads. I thought that was a good idea, but I'm not sure how rubber bands will hold up over time.
Does anybody have any ideas? Maybe I can buy a new plug (since I've tried multiple times to get this one to work, and the threads are certainly no longer pristine...besides, Home Depot sells them for 99 cents) and buy some RTV gasket compound of some sort, then goop it on the top threads and let it dry? I keep mentioning top threads because that will allow the bottom threads to catch and allow me to turn it a few rotations before the gasket makes contact.
Again, for the life of me, I can't understand why someone would approve such a design to stop water from coming from the ground (or keeping 11K gallons of water from leaking). Any advice would be GREATLY appreciated.
I should be clear that the plug is merely nothing more than a plastic bolt/screw without a head. There is no lip or head to stop it from screwing down past the drain hole. Also, my pic of the drain has the plug installed. I've tried many times with teflon tape; no dice. I didn't take a pic of the drain's threads...they just abruptly stop and then I can feel small rocks below. So, I guess I could keep screwing the plug all the way down to the rocks - but there's not point in doing that. Why didn't they use a design that had a hard stop with a gasket?!?!?
