I currently have a single-speed pump that I turn on/off via a switch that is on a brick wall right next to the pump.
I am replacing that single-speed pump with a variable speed pump (Hayward SP3202VSP) that has a built-in programmable timer and touchpad control panel. So I presume I will be able to turn on/off the pump directly on the pump using the touchpad.
It seems like I could get rid of that switch and simply run the wiring directly from the panel to the pump.
So my question is do I still need that switch wired to the new VSP pump? Does the new pump make that switch obsolete?
