It's crazy that over 99% of the pool professionals on YouTube all promote adding the floating chlorine tabs. I'm new to all this and learning a ton on this site! So I have also been a victim of using tabs for a year. I have a feeling my CYA is high (I need to buy the test kit recommended here).
1) My questions is. Some of the pool pros say that living in hot areas, like Los Angeles, say the pool water will evaporate because of the sun and the new water coming in (via auto refilled) will dilute the CYA which is why they don't worry about recommending the chlorine tablets. Could this be true?
2) Can I just add more water from my hose into the pool to dilute the CYA?
Thank you!!
Thank you!!
