- Jun 1, 2018
- 16,076
- Vinyl
- Hayward Aqua Rite (T-15)
I posted in another thread last night but decided to start my own thread as to not hi jack that one. Here’s what’s happened—
5/2/20: I wanted to point out something that happened as I went about my ahhsome flush. My water is 6mos old. This is the longest I’ve ever been on a h20 changeout. I Usually do it every 3 months (always with ahhsome) but decided to delay until warmer weather & after i got my pool going. I keep with the dichor then bleach method & have a saltron mini that runs on a timer for an hour 4 times a day unless i add an hour here & there. I also augment with bleach for heavy bather loads. To my knowledge I have never been below the min fc level for my cya ( I’m a compulsive tester ?) I have noticed my demand getting a little higher recently but that’s to be expected. Anywhoo I brought the tub up to shock level, pulled my swg out, threw my rinsed filter in the tub & put in 2 tsp of ahhsome & turned on the jets. Water was 106 degrees. The foam began - I started scooping- no funk - ran about an hour- got a tiny amount of “residue” off the shell but not much - & no colored foam. So i proceed to wipe, rinse & drain etc. I fill Her up - confident in my purge - i add 10 ppm dichlor & my salt . I noticed the water didn’t look blue like it usually does it was more dingy looking (my spa is beige but my water never looks beige) . I let the jets run & go in for like 20 minutes. When i came back out There was brown goo! Like randomly floating & collecting on the side ?. So I run & grab more ahhsome & add a tsp - 10 minutes later there was brown greasy specks all in the foam & on the sides?. Scooped & scrubbed all that out & added another scoop & ran another hour to be sure. Now I’m filling again. From now on i will always do a 2nd purge.! I will also be back on the 3 month regiment. I’m sure its due to my hubby not scrubbing his hands & arms well enough. He’s a pipe fitter & really gets black. Chlorine can only overcome so much. I may also look into the ahhsome maintenance product.
5/3/20: after fill was complete last night I raised fc to 15 w/ dichlor according to pool math. Left the tub open for a couple hours (water looked great!) & decided to call it a night. This morning opened the cover & there it was -A brown scum line! I wiped/ scrubbed it off & tested:
FC is 15.5
CC is .5.
Cya is approx 13
Should I raise fc? if so how high?
I purged 3 times with 2 drain & fills the 3rd purge was clean.
I only have a tiny bit of Ahhsome left.
I want the CC gone
@Ahhsomeguy - HELP!
FC is 15.5
CC is .5.
Cya is approx 13
I want the CC gone
@Ahhsomeguy - HELP!
