DE Filter Was Leaking - Clamp not Tight; any other concerns?
njech
Active member
May 30, 2020
43
South Jersey
My pool company (former...) replaced the grids in my DE filter last season. It never seemed right to me after since it would leak. I was a lazy owner and just didn't look into it. I opened the pool this year (first time doing that) and of course it continued to leak, since the problem didn't magically solve itself. Found some threads on here with a similar issue and the clamp probably wasn't tight. Well, I'll say! It seemed to be on just enough so that it was considered on. I do not have a torque wrench that does 150 pound feet of torque so I tightened it up quite a bit and have about a half inch of the screw coming out the other side now. And no more water seems to be leaking.... :)
I'll keep an eye on it and see if I finally have a dry pad after a couple of days. Anyway, should I be concerned of any premature wear with anything else for my pool since my filter clamp was barely tightened. I wouldn't think so but figured I'd ask the experts!! Thanks.
It’s actually 150 inch-pounds of torque, not foot-pounds. You have to be careful over tightening the bolt as it is brass and you can strip it. It’s $30 to replace the screw and bolt but nearly $400 to replace the band clamp so be careful with it.
There’s no harm in a leak other than lost water. Take the filter apart sometime and make sure the o-ring is lubed and not damaged in any way.
