That recommendation comes from the experience of many SWG users. For most, when the CYA levels drop below 70ppm, chlorine loss rates go up. I know this to be very true in my own pool and it's one of the early warning signs to me for when I need to test my CYA. As soon as my CYA level drops below 70ppm, I start to have to increase my % output to keep up my FC level. However, when my CYA level is at 90ppm (I tend to keep it on the high side), my FC loss rate is much lower and I can maintain my FC level with less % output.
@chem geek posted this many years ago.
Read this post and
follow the links to
@mas985 's experiments he did in his spa. It very clear that the traditional chart of FC loss rate versus CYA concentration is not quite correct at the high end. It seems that there is an "anomalous" screening effect that is not accounted for in the basic chemistry of chlorine and CYA. Experience seems to show that higher CYA levels are much better for chlorine stability BUT you have to balance that against the risk of an algae bloom as higher CYA levels demand greater shock levels of chlorine to be effective. This has traditionally been the bane of most pool owners because service companies and pool stores will ignore CYA levels and then pools become much harder to control when algae gets going. But, because TFP teaches self-reliance and self-testing, many problems can be headed off early well before a pool ever goes pea soup green. SO in my own pool experience, I don't fear high CYA levels because I know that I'm going to catch problems before they ever start.
