Creating a plan to fix OG Inground pool
freeqaz
5
Seattle, WA
Howdy TFP,
Been a lurker for a few months and I've loved so much of the advice I've gotten here. Y'all are phenomenal and I really appreciate "sticking it" to BigPool that eats the wallets of too many people out there.
Anyway, I am posting because I'm in a weird situation that I'm trying to figure out the best course of action for. I bought a house with a pool that has been neglected for many years and none of the equipment works.
Well, the equipment worked for a bit until I got new electric work done and the electricians ripped out the connections to everything. But even when it was "working", it was more "limping" and had some major issues (stuck 3-way valve meant water would siphon to waste, so it wasn't possible to use anything).
I'll get into the actual equipment in a second for what exists. Let me talk a bit about where I'm at today.
Pool Specs:
Around 11-12k gallons. It's a weird irregular jellybean shape, and this is my best estimate after SLAM'ing and seeing how chlorine levels change. There is a small hot tub next to it as well with separate pipes for jets/return loop.
It's plaster, I believe, and once upon a time I had drained it (before I realized the risks) and it never floated or cracked (fortunately!). Seems pretty sturdy and solid.
Current (jank) Setup:
I have an Intex above-ground pool pump running with glass sand (link, I have the 2,800 GPH version).
It's just chilling next to the pool with one hose in the skimmer and the other running water in a circular motion at the bottom. It seems to work alright -- I've been able to remove the grotesque amount of leaves and get it so that I can see the bottom after SLAM'ing it to heck and back. (thanks to everybody on the forum that posted to help with this)
I also bought a pool roomba (Dolphin Cayman) which helped. Current getting RMA'd.
Biggest issue was that I had used flocculent early on (advice from a pool store) and clogged the sand up after partially vacuuming it. Took me a while to figure out the filter was clogged -- ended up hosing down the sand and blasting it until the water ran clear.
Anyway, now I'm at the point where it's _almost_ fine, but it's still jank and I'd like to figure out a long-term solution that lets me heat it to a warm enough temperature for lounging (it's around 74f currently).
OG Equipment:
Sand Filter: A gigantic sand filter that's a pain in the rear to open up, like 30 rusty looking bolts. The body is carbon fiber, I believe, and it's ancient. (I'll upload pics at the end of the post)
Pump: Some old pump that only ran when I manually primed it. Seems fine but likely super inefficient.
Heater: Zodiac LRZ250MN from 02/2012.This was seemingly replaced by the last owner but it doesn't work.
(Note: I had a pool repair guy come out to look at it and he said the control board was fried (it's a "microvolt" heater type that uses the gas to power the circuitry instead of external AC). I couldn't find a replacement board when I looked online.)
The pipes are all 2" PVC I believe. Like I said, the three-way valve on the sand filter is stuck partially open and none of it works anymore so I can't test it.
BigPool's Advice:
When I had the pool repair guy come out and I asked him "how much to fix it?" he gave me the ballpark estimate of $30k. For something that adds close to $0 in property value in the Seattle area... I was not interested. This was maybe ~18 months ago. (And that didn't even include resurfacing the pool which has some pitting
That's what spurred me to eventually think about this more and decide to try out the off-the-shelf Intex sand filter. It's jank, sure, but it's $250 + $80 for glass sand. A literal drop in the bucket by comparison! If I could get that to work then at least it wouldn't be an algae pit for mosquitoes (one problem solved).
Fast forward a few months, and a lot of lessons along the way, here I am looking for advice. Let me spell out what comes to mind for me.
Current Questions:
Even if I had $30k to spend, I don't really want to give it to BigPool unless it's what TFP recommends. I'd rather "hack" my way to a solution and help future pool owners out by sharing that information more broadly.
Question #1, turn temporary into permanent?
I could rip out the existing equipment and hook up either the Intex 2,800 GPH setup or buy a different off-the-shelf-ish filter + pump to wire up.
I feel like this could work but I'd be worried about the longevity of the Intex pump. It has been pretty slow to filter the water off (maybe my fault for not realizing it was clogged) so either it's too small or I'm too impatient. (Maybe it's fine if I properly cover the pool in the winter and, once I get the water spotless, it won't be an issue again?)
Any thoughts around what makes sense would be appreciated. It seems like going from 2" PVC -> 1.5" at the filter won't be a big deal. (GPH limits for 1.5" pipes seems to be somewhat of a myth anyway if I did try to "size up" the pump but not the filter.)
Question #2, what to do about the heater?
It's a natural gas heater that's 250k BTU and about 2ft from the electrical sub-panel. But it doesn't work and I'm not sure why. I do have an oscilloscope and I can solder, so I'm not afraid of trying to debug it. But power electronics that deal with natural gas is not my ideal hobby project 🤣
I'd be open to paying to get a new heater installed, but will anybody install it if it's connected to an off-the-shelf pump? I don't want to accidentally find myself in a spot where the heater is on but water isn't flowing. I assume heaters have fail-safes for this, but who knows.
If replacing it seems like the better move, what's the ballpark cost for that? If it's just a few thousand that would be fine. It already has exhaust venting to a chimney, natural gas laid to it, and an electrical panel accessible. (I'd be open to a heat pump but with the hot tub it feels like gas is the better choice.)
Question #3, am I crazy? Or just naive?
Maybe all of this is complicated enough that it is worth getting a professional to turn-key replace everything. I just feel like there is a way to do this for not a wild amount of $$$. If y'all think that's wrong though and I should just save up the money, I'm open to that too. I just want to check in first.
Thanks for reading this wall of text. I am very appreciative of any words of wisdom others have to share. Cheers!
Howdy TFP,
Pool Specs:
OG Equipment:
BigPool's Advice:
Current Questions:
Welcome! You can replace the filter with a more modern cartridge filter and also replace the heater if the heat exchanger is corroded/leaking.
Neither of those things though is needed for fixing the algae pit. The filter helps a little but is not required. Just need chlorine circulating.
Stay away from intex pumps/filters. Also dont waste money on glass filter media.
Thanks for the prompt reply!
I think the current cloudiness I'm facing is from putting food grade DE in, whoops. Just found a thread about the difference between that and pool grade. 😅
Good to know about just needing chlorine. I might go grab a cartridge filter to use if that's a better choice for clearing things up. I definitely wouldn't complain about a smaller setup!
Also just learned about the glass vs sand. I had no idea and bought sand because I thought it was more effective. Should I toss it and just grab some pool filter sand to replace it? Is it possible that the flocculent I added nerfed the glass media? (I don't have a kiln to reactivate it, just a hose and pressure washer lol)
What are your thoughts on replacing the control board in the heater? Is a ~12 year old heater that's only had light use worth trying to fix? I'll see if I can figure out if the heat exchanger is busted or not. Will report back!
Floc getting into the sand filter can wreck the sand. If that happened, you need new pool filter sand. Glass media is just expensive and performs the same as cheaper pool sand. Did you add DE to the filter too? Dont do that again. Some people do that when the pool is 99% clear and want extra filtering but you are no where near 99% if theres algae. DE just clogs it up faster.
It's definitely filtering a little bit still but I'll grab some fresh sand tomorrow and give that a shot.
It does seem like the floc should eventually break down or at least it can be "scrubbed" with a deep clean (which I did and it resulted in some veryyy dirty water coming out). Found this page.
If fresh sand will help fix this problem though I'm all for it. I would love to have the pool be totally clean!
I'm looking at pumps to replace this Intex one. The Black+Decker VSPs seem solid and for my pool size it looks like I really only need ~8.5 GPM to exchange the water once per day. Obviously I need to exchange it more under heavy load, but even a 1hp VSP should be capable of ~7 exchanges per day when run on high with the ~11k gallons I have. Looks like that can be had for around $630 and is 110v which is easy to deal with.
Only issues is that it's an above-ground pump so it isn't self-priming. Not sure if that's a show stopper or not (can always pour water in the skimmer or shove the hose on it, but again not ideal).
For in-ground pump it seems like 1.5hp is the smallest I can find that isn't from an ultra-garbage brand. (B+D 1.5hp is $1100ish) It's 220v but I can just pay an electrician to add a new breaker.
Any thoughts on that?
For replacing the various PVC pipes that exist, I'm wondering if that's something I should tackle myself or find outside help for. I feel like I don't need a dedicated pool guy to do that work and a solid plumber should be able to tackle it, but curious to hear any thoughts on this. It seems like it should just be a question of buying the right arrangement of valves to swap pool/spa returns and connecting it to a filter with a 6-way valve. Is there anything I'm missing there?
Trying to find some threads of people doing something similar. I'll post links if anything pops up.
You dont need to worry about turning the water over X number of times per day. Thats an old myth. You run the pump at the speed which makes the skimmers work, heater turn on, SWCG make chlorine, etc. We typically advise running the pump as slowly as necessary. If you get a variable speed pump, the cost to run them goes down as the speed goes down. Mine runs 24x7.
You dont need a pool plumber to make PVC changes, anyone with basic PVC skill and tools can do that stuff. If the pipes are not leaking then theres no need to mess with them though. Theres no benefit to increasing/decreasing pipe size.
I personally would not buy an above ground pump for an inground pool. Pennywise and pound foolish as they say…
If the pool is plaster, I might make sure there are no leaks in the shell before spending money on equipment as fixing a shell leak will be way more expensive than replacing equipment and that may steer your plans.
