Brand new to owning a hot tub and after having it set up for 2 1/2 weeks now, I decided to read the instructions. I actually was looking for a plumbing schematic for a small problem I was having and I came across this warning in the manual. It states that they highly do not recommend placing the seam of the cover over the control panel. I put the feet of my diy tub cover lifter under the tub before it was filled so I am a little bit stuck on how the cover gets placed on the tub. How important is this and for what reason would it reduce the life of the control panel. Is it the sun getting into the panel or the water vapors getting out that they are worried about. If I knew then maybe I could devise a way to make it a non issue. Any thoughts or guidance on this matter. I can reorientate it when I do a drain and refill but wasn’t planning to do that until it gets above freezing here in about march.
