Pool was Initially clear before memorial day, but the salt was borderline low, and the swg went off for 2 days for low salt before I noticed. I added more salt and shocked since it turned cloudy.
The next day, this persistent green appeared. The water is as clear as it can be. There is hardly any pink on the CC test. I've been holding the FC level for 5 days now with no change
Is it possible that the salt had copper in it? I used regular water softener salt, which I have used in the past with no issues.
Reading some other threads, letting the FC drop down may actually get rid of the coloring if is copper, but not if it is algae. Anyone with a good eye have an opinion?
PH- 7.4
FC -28
CC - No color change
CYA - 70
PH- 7.4
FC -28
CYA - 70
