I'm considering re-purposing a 1" line that was originally used for a booster line and a 1.5" skimmer line into a single 2.5" line that will then feed the pump. The question I have is, since the addition of the 1" line is to reduce vacuum losses on the 1.5" line (to get more flow), is it better to use a simple 2.5" Wye Waterway Manifold Wye - 2.5 - 672-8050 or should I use a Jandy never lube 2.5" valve & attempt to mix in the correct proportions. Since the intention is to not have either line exceed the other in feet per second of flow (to reduce vacuum losses) I'd figure a wye makes the most sense.
