- Jun 16, 2015
- 50
- Plaster
- Hayward Aqua Rite Pro (T-15)
Long story guys, but here goes.
Been a fan of TFP for years. read forums like a stalker when I have an issue. Usually can solve problems without posting. Been through a pool build and have had a TFP (for the most part) since. I can actually tell when I am going to have an algae issue by consumption of chlorine (usually). Had some issues with keeping my CSI in the parameters of TFP to avoid scaling. I have some limescale on my waterfall where it touches the tile grout when the VS pump is just keeping water flowing.
SLAM'd Pool due to algae bloom pending, (found out it was from algae in the corners of my coping.) Added Borates to help with PH and CSI and CL. Had PERFECT water for about a week. Almost hurt to look at it in the sun it was so clear. Passed OCLT, let levels drift down to normal after SLAM. Water has eventually began getting cloudy, even though numbers have been good. Just posted my last full set of numbers and realized that I am out of R-0871 (grrrrrr!) but should have more in two days. So until then no OCLT. I know that its the tell all, but I just don't see how it can be organic with everything being balanced so well for the most part. So while I am waiting for my reagent to arrive I thought that I'd see if there was anything else that I'm missing. Will post some thought that I had but wanted to defer to some higher "authority". Thanks in advance.
Thoughts:
Scale buildup from high CSI and now being pulled back into pool?
Palm tree on outside of screen enclosure dropping enough organics to cause?
Recently scanned through a thread about cloudy water and read that 1 scoop of powder is sufficient for .5/drop measurement. Have been using 2 scoops since having pool so wrong testing procedure?
Recently cleaned filter (about 2.5 years old) but have not deep cleaned it. Pressures seem to be ok.
Something else that I haven't though of?
Thoughts:
