Good Morning,
So the pool was completed in early March. I have been in charge of chemicals since after the first week. Been using TFP method all along. Got the chemistry balanced and the pool looked awesome...until this Saturday. I'm in the DFW area and we got about 4" of rain on Saturday and the pool started to get quite cloudy. At first I thought it was just maybe the rain itself that was making the water cloudy, but then I started searching on here and found that should not be the case. Anyway, I immediately started to SLAM Saturday late afternoon. I'm more curious than anything why something got a hold of my pool when my chemicals were balanced. Here were my readings from Friday night (before rain):
FC: 6.5
CC: 0
PH: 7.6
TA: 70
CH: 225
CYA: 50
So Friday night I added enough Chlorine to get me back up to 8ppm. Water looked awesome. Saturday, when I noticed the water started to get cloudy and after about 3" of heavy rain and storms, here were my test results:
FC: 5.5
CC: 0
PH: 7.6
TA: 60
CH: 200
CYA: 50
So it looks like the overflow from the rain got rid of some of my TA and some CH. And a little more FC loss than normal. But Chlorine stayed above recommended minimum. I've maintained SLAM levels since Saturday evening and the water has started to clear up some, but still a little cloudy. Pump has been running just short of max the entire time. I did an OCLT last night and passed. CC has been zero the entire time. I tested about every 2 hours yesterday. I'll keep at the SLAM until water clears up, but just pondering why this happened in the first place and if in the future I should bump up FC levels before a big storm.
FC: 6.5
CC: 0
PH: 7.6
TA: 70
CH: 225
CYA: 50
FC: 5.5
CC: 0
PH: 7.6
TA: 60
CH: 200
CYA: 50
