Closing with shop vac.
Newdude
35,132
NY
Today was the day for closing and it went great with a 6HP shop vac. I hooked my blower up for fun after, and there really wasn't much left but some spray.
Anywho I wanted to do a write up for all the folks wondering if they could save a chunk of change and tackle their own closing.
First, I vacuumed. Everybody can already do that. Then, I drained below the returns. I used my main drain and waste line, but a submersible pump would have worked also.
I put the shop vac hose on the exhaust post so it would blow, and it was a perfect fit in the skimmer hole. As soon as I got it in there, water was coming out of the returns. It wasn't violent like it would be with a blower, but once the bulk of the water was out, it spit like a cyclone would.
Only the first return emptied being the 1st stop on the run. So I plugged that one and the remainder of the water blew out the other return.
That was too easy, so I filled the pipes with the hose and took apart the equipment pad in order to isolate the lines like some of you may have to do for a shop vac to work with complex systems. I used duct tape to seal the hose to the line. Just a few wraps is plenty. 20221119_134714.jpg
The return looked like the above pic again. The skimmers blew pretty impressive for a weak blower.
Then I hooked up my (768 CFM at the nozzle) leaf blower to see what was left, and there wasn't anything left but drips. Again, a few wraps of duct tape made the seal.
The returns got plugged and the skimmers got gizzmos with Teflon tape on them and some cut up pool noodles.
The filter got drained, the carts came out and got hosed off.
It was 38 degrees playing with the hose so.i didn't go crazy cleaning the carts. I will probably give them a TSP / acid bath in the spring. For now, they are clean enough and drying in the garage.
The spare parts, gaskets and drain plugs all got put in a skimmer basket on my workbench for easy finding in the spring. 20221119_152644.jpg
The pump and SWG will come indoors. The filter will get stored in the shed once the carts dry. I will seal the openings so no critters get in there.
They will be installing my cover soon, but every year from now, I will float it across the pool and hook up one strap at a time until they're all on. It's that easy.
I'm curious...I can't tell from the pictures. Did you remove the weir doors? I always remove them I'm fearful that they will be locked in ice and break the tabs, or break the tab holders in the walls.
Would love to see a picture of the cover when you get it...
Anywho I wanted to do a write up for all the folks wondering of they could save a chunk of change and tackle their own closing.
That was too easy, so I filled the pipes with the hose and took apart the equipment pad in order to isolate the lines like some of you may have to do for a shop vac to work with complex systems. I used duct tape to seal the hose to the line. Just a few wraps is plenty. View attachment 463029
Then I hooked up my (768 CFM at the nozzle) blower to see what was left, and there wasn't anything left but drips. Again, a few wraps of duct tape made the seal.
The gizzmo pictured is missing the O ring, was it put back before the install.
It didn't come with any and my old ones didnt have them either. Maybe its the new model, or this brands way ?
It's taper was pretty defined and it is in there nice and tight. GREAT looking out tho, THANKS.
Reactions: oledan and Leonian
