Hello TFP,
I just noticed this morning that my pump and/or the plumbing connected to the pump, is leaking and forming salt deposits on the floor.
I use liquid bleach as my sanitizer and muriatic acid to manage the ph level. TF100 test kit. Gunnite pool.
Unfortunately, I’ve been a little negligent the past few months in keeping the ph in the correct range. It often gets up to 7.8 - 8.2. CH is 450. Another factor to consider is a lot of white, chalk-like powder on the walls and floor. I’ve been scrubbing the walls with a scouring pad (to remove a green stain-cause unknown), little by little, resulting in clouding up the whole pool (white, chalk-like powder), taking several hours to clear up. Water is always crystal clear, otherwise.
I thought at first it might be the ph, but now I’m thinking it might also be the white powdery substance (calcium?) that used to be on the floor and walls, blocking up the plumbing. As well, the pump, installed new last fall, sounds a little louder than usual today, and we’re sensing increased vibration in the house (indoor pool, pump and filter in the basement).
Does anyone have a take on this problem and how it can be resolved? I was thinking more diligence on the ph level, but I think that might not be enough.
Thanks for your help.
Tom
Tom
