I spent at least an hour reviewing threads on this forum and reading everything from "cavitation cannot be seen in the strainer" to "cavitation can occur with too much velocity / turning just before the inlet" and also describing cavitation as "champagne bubbles" which I believe is what I see. I believe it may be that. I also here strange "cracking noises" or more accurately, "knocking noises" but they are few and far between and haven't been able to locate where it is coming from. I tried the "run the hose" method over the valves, joints, and pump basket to no avail. But I'm not ruling out a suction side air leak...
I just finished re-doing my entire filter / pump setup and all of the plumbing associated with it. I even tore apart and re-did a portion of it to get as much straight pipe into the inlet of the pump as I could as I previously had a 90 right into it. No water leaks!
I am not getting any air out of my return jets. I also don't appear to be getting any build up at the top of my filter. I had this same problem with my last setup when I had everything full-open, valve wise. I found that if I closed the flow a bit coming in from the main drain that it would get rid of the bubbles in the strainer. This is the reason I am thinking it's not an air leak. Unless of course the leak is so small that it just requires a certain amount of pressure to start penetrating. With the new setup if I try closing the flow from either the skimmers or the drain, the problem gets WAY worse. Like, insanely worse. Leading me to believe maybe the pump is too strong. Yet, the flow into the skimmers is good and the GPM I am seeing is what the filter wants as well.
All of of me new equipment is in my signature. My old equipment was also a 1-1/2 HP pump (century ST1152), but with almost the same service factor HP (2.20 vs 2.25 with the new one). I wanted to up the HP a tad as I had always thought my flow rate was a little low. Took a long time to prime, skimmers seem to have sub-par suction, etc. I actually would reduce the flow from the main drain in order to increase it in the skimmers to make them more effective. However, it was/is obvious that a larger pump was overkill.
I also upped the plumbing between the original intake lines and original return lines (1.5") to 2" piping. So I have two 1.5" pipes feeding into a jandy valve exiting into a 2" pipe. Visa versa for the return lines. I'm seeing 70-90 GPM flow rate. It started out pushing 90, but then I reduced flow to one of my return lines which brought it down to about 85. Unfortunately I have one 1.5" return line that feeds two return jets on one side of the pool and then a single 1.5" line feeding another return on the other side of the pool. This was originally used as a vacuum port for a Polaris cleaning robot. I have a jandy valve there so I can even out the flow between the 3 lines. However, this does mean that my discharge is slightly smaller than my intake (two full-open 1.5" lines vs one full open and one half open 1.5" on the discharge). Could that be the problem? If so, I have no solution other than to reduce the intake which makes the problem worse.
Anyways, the GPM is now down to 70-75 after running the pump for 12 hours and getting dirty (going from 18 to now 23 psi). The pump has worked awesome. Took a very cloud and dirty pool to crystal clear water in 12 hours. Really, other than the bubbles in my pump, everything is working great.
So I think I gave enough back story and detail. Here is a video I took of what's going on in the pump. I took it in slow motion mode on the iPhone (at night last night) so the beginning and end of the video show real-time speed: File_000.mov - Google Drive
Here is a picture of the new setup:
IMG_0514.JPG - Google Drive
And here is a picture of the old setup:
IMG_0515.JPG - Google Drive
Long story short -- should I be concerned about this? Are these bubbles enough to try and go crazy finding their source? Leave well enough alone?
