Brand new Hayward T-Cell 15 seemingly over producing chlorine, is this a problem?
BasicTek
0
870
Lake Mary, FL
Hi all,
I just recently switched to a Hayward SWCG witch is quite over sized for my pool (T-Cell 15 for 40K gallons and my pool is about a quarter at 11K gallons), Per pool store, this site, and the internet in general, everyone said to get over sized especially for a year round Florida pool that gets a lot of sun. That combined with a sale that got me the T-Cell 15 for a little less than the T-cell 3 pretty much made my decision.
So initially right after the conversion my FC was skyrocketing (up over 15) running at about 30% for 8 hours. This turned out to be mostly caused very high CYA (between 180 and 220) at which I was only loosing about 1 FC per day when I turned off the SWCG all together. So fast forward to today I've reduced my CYA to 80 (maybe 90 but 2 out of 3 tests are at 80) and I'm maintaining my FC at 5-6 running my SWCG at 6% for 8 hours going on 2 weeks now.
In my head I'm thinking I'm sized at 25% in FL with a southern exposure pool (albeit screened in) and using the SWCG calculator here I should be running around 37% with my FC loss per day probably around 2 (I had to turn the SWCG off a day because FC went to almost 8 and it was only down 2 the next day). Now if I was off by 10-20% ok but I'm literally running at 1/6 the guestimated amount. At this rate my extended t-Cell could last about 50 years lol
I've searched the forums and I see literally 100's of posts where people are not getting enough FC out of their SWCG but I couldn't find a single one where they were getting too much. I was really just counting this as a blessing until I found that calculator and now I'm wondering if my SWCG is not functioning properly such as the % setting is not accurate. Should I get it checked out or does anyone else have this (not really problem) but situation?
-Tim
Awesome, is all I can say :whoot:. I don't think I'd consider this a problem. I think I'd consider the calculator as a general guide to get in the ballpark and then adjust from there. You can play with the numbers on chlorine production, pool volume and FC loss and get where you are. Who knows, maybe Hayward stuck a few extra plates in yours than others ;).
Why are you running the SWG for 8 hours? Try cutting that down to 4 hours and adjust % a bit higher (10-20%).
Consider your situation a blessing. That cell should last forever LOL.
I have a variable speed pump and I just haven't reduced it yet, but I was running for solar. I was planning on dropping to 4 hours in the morning and doing just that but was just curious why I was able to run it so low...
You can't set independent run times for the pump & SWG? I meant to only reduce the SWG run time.
You can run it so low because it is so oversized for your pool. You made the right choice, and should get a very long life from that cell.
My SWG is set to run on it's own manual timer, but also connected to the power on my pump. I was planning on reducing my pump anyway since I don't need the solar as much during the summer. I just thought I should check here on the SWG 1st because it seemed really odd that I was using the SWG so little. I guess as ya'll have said this is something to celebrate :kim:
I'm really surprised that my pool is now very low maintenance I use less than $10 of chemicals a month (about $5 for Muriatic acid to keep PH down, and probably $2 for baking soda occasionally to keep TA up) I have more calcium and stabilizer than I'll probably ever use, and if lucky will not have to touch my SWCG now for many years to come. That's definitely the definition of a trouble free pool lol
So glad to hear that your pool is truly Trouble Free!
Last year I only spent $63 on 12.5% bleach for the entire season. This is my first year with a SWG, and I'm loving it so far. I've only been on the SWG for a few weeks, but only used a couple of gallons of bleach until the water was in the solid 70'sF, and a few lbs of cal-hypo for open, which only bumped my CH up to 50ppm (very soft water here, CH out of the tap is about 20-30ppm), so $12-15 for chlorine this year!I
If my pH stays at 7.4 as it has always been with this pool using bleach, the gallon of muriatic acid I bought may not even be needed.
Talk about Trouble Free!
Wow that's even lower than mine. PH has been my only negative since converting, I've only had it since May, and used over 2 gallons so far, but the water looks and feels great and I probably never need to touch a chlorine puck again :cool:
