- Oct 25, 2015
- 5,809
- Plaster
- CircuPool RJ-60 Plus
OK,
My wife coined that word. It happens when you can't stand to use strips for anything even borates when you say "there's no other way to test it". I way over-dosed when I originally and used a test strip that barely registered so I just went by the Pool Math calculation but this has bothered me ever since. Now it got so bad that my TFPicitus has started flaring up every day... I won't tell you what the symptoms look like. It's horrible! My salt was reduced almost 30% just this year due to the massive rains. My borate test strips looked the same as they did at 60. Every time I ran the strip test my symptoms got worse! I finally had to be honest with myself and come clean. I knew there was a better way that @JoyfulNoise wrote about years ago using some modified TF100 test with a few additional reagents. So, dug it up and voila!
For some reason I always thought this would be complicated, hard, and not worth it. Boy was I wrong! This test is easy peasy just a step or two extra. But now I know I have 12 ppm. I feel like my TFPicitus is getting better now. The symptoms were completely gone when the straw yellow sample changed to baby blue. Yes 3 drops, 12 ppm. The symptoms went away as I put the reagents up. I'm symptom free as I type this!
If you have borates and haven't tried Matt's test you should. It's very easy and the extra's are available cheap on Amazon. Matt's instructions and links to supplies are here, post #135. Matt, thanks so much for this. I can't wait to add more boric acid tomorrow and then run the test again to see it confirm!
Chris
PS my wife is shaking here head
Chris
