- May 6, 2016
- 74
- Vinyl
- Pentair Intellichlor IC-40
For the previous two years I used Borax and Muriatic Acid with what seemed like relatively accurate LaMotte Borate Test strips. Water sparkled and softer, pH more stable, level around 50ppm to start - definitely pleased.
Second spring the level was down to around 30ppm (and I brought it up again).
This year I could not find the LaMotte Test Strips anywhere in Canada (or in the US at a reasonable shipping fee), and could only get the Hach AquaChek Borate test strips.
Tested the pool andthe strips indicate 0 Borate!? the strips indicate 80+ppm Borates (I was assuming no colour change equalled no boarates - see below. Same question applies though.) Is that possible? (I didn’t do a large water change, however there was a significant amount of snow and rain this winter/spring.... but 80 (when I thought I left it at 30-40 end of last summer!)?
Anyone know a good mail order source (or Canadian supplier) of the LaMotte Strips? (They were good enough that I don’t think I need to invest in a titrate test. BUT I need something. No one around here uses Borates in any number so LPS don’t test for it.)
Thank you!
Tested the pool and
Thank you!
