Hey everyone!
I am running a Flowclear 1500 gal/hour sand filter on my Bestway Steel Pro Max 16'x48.
bestwayusa.com
I finally got all the "gunk" out of my pool - and in doing so - when I backwash/rinse I flood my yard... mainly because the tubes they provide are only 3-4' long. I cannot for the life of me figure out a hose attachment that goes on the end of the pump where backwash water flows from. If I could run a 100'+ garden hose from the pump, I would be in a much better spot!
Pic attached
Thanks!
Bestway 1,600 gal. Above Ground Pool Sand Filter Pump
Keep crystal-clear, clean water flowing through your above ground pool with the Bestway® 1,600 gal. Sand Filter Pump! This powerful pump lasts longer, is more environmentally-friendly and requires less maintenance than a traditional filter cartridge pump.
Pic attached
Thanks!
