Attention DIY Liner Experts
Styxbb
0
May 5, 2014
91
Ohio
Hi, I am in the market to replace the vinyl liner in my inground pool. I have downloaded measuring forms from various sites but my measurements are showing inconsistencies that aren't addressed on the forms. I will include a pic with my measurements. My main concern is the hopper in the deep end is not quite square. Does this mean I will have to fix it before installing the new liner? If so, what measurements should I use? The measurements in question are highlighted. I am a fairly handy guy and felt this was something I could DIY. Would you recommend a pro?
Thanks
Are you hoping to get a ready made liner? Quite a bit less money but the fit may not suit you.
I have put in two custom liners and the fit was pretty accurate.........I measured down to the 1/2 ".
Custom or ready made.........that'll determine how much precision you need.
It can certainly be DIY but you will want some help. I used 4 guys in my big pool and two vacuums.
I have replaced the liner once myself. Then I learned that I had inverted a measurement and created a big wrinkle in my pool. Been there for 10 years now. It will be a custom liner, but none of the sites I have found allow for the variations in the side wall of the deep end. I have found some closeout patterns that I can get for 1300 for a custom 28 mil. Most prices are around 2300.
