My swg was giving a low salt/check cell message. It was giving low salt reading (1400) while my Taylor kit said 2800. I cleaned cell but no difference. I assumed it meant that cell was due for replacement. This is the first time I've had to deal with this so have some questions...
1) I've read that cells last about 5 years. Is this based on year round use or seasonal? Mine is 8+ years old. Not sure exactly how old as it was installed/replaced by previous owner. It was a T-15 which seems oversized for the pool size (13000g). I ran it at about 10P. Does this cell life make sense for a pool used only in summer?
2) I found a brand new T-9 that previous owner left. I have software version 1.58 so was able to switch the control panel to this cell. So far cell readings look okay but it's only been a couple of hours. Any issue downsizing? If my T-15 was set to 10P what should I use as the starting point for this one?
3) Is there an advantage to a T-15 vs T-9 for my pool size? A T-15 cell costs about 35% more than the T-9. Is it worth it?
4) How long does a flow switch last? I've never replaced it so must be 8+ years old. Does it requiring cleaning periodically? I took it out and attached is what it looks like. Is this normal? Should I be concerned that it's not in an 'open' position?
5) Would T-15 and T-9 have same flow switch? I found an extra unused one with the T-9. Can I use it when this one fails? When I searched online the part seems to be compatible with all models.
