Hello pool folks. See you if you can make sense of this riddle below. Look forward to your insights on this puzzling matter.
Pump wasn't working so investigating with a multimeter.
1) Aqualink RS in service mode - filter pump button is the subject.
2) If i press the filter pump button, it clicks but about 1/3 as loud as all the other buttons.
3) relays are fine. I could actually just hook up the filter pump relay with the Aux 3 line (and other lines) and run the pump with Aux 3 button. (which is what i'm doing right now to keep the algae away)
4) but funny enough if i disconnect the filter pump 24v line and test with multimeter, i still get 24V actuation when i press the button. (again, softer than others)
5) but if connected to the relay and i test at the screws, does not show 24V when button on.
Questions:
- Do you know what this 'soft click' means and why it doesn't provide enough power to run the relay?
- If i can't figure this out or fix it, any risks in continuing to run the Filter Pump with the Aux 3 button?
Appreciate the Help!!!
Questions:
