Hi all! Happy to be here and posting. I've been reading pool school and all resources for the past few weeks and am hoping I'm on the right path, though I believe the only answer at this point is to drain and replace. I am trying to avoid right now. We did accidentally drain and replace about 6-8 inches three weeks ago. Water is expensive here.
- Never owned a pool; purchased home one month ago;
- History from previous owners: ran heater at 92F all season (we have not had heater on, brand new heater); pool always covered except during swim time; metal problem; had been using approx 9 trichlor tabs per week in an auto chlorinator set wide open at 5; had a CuLator in the skimmer; told us to go to Leslie's for the water testing.
Us:
- started at Leslie's for initial testing; ran through one round of Metal Remover and Soda Ash, started doing research and realized I wasn't going through the "buy all the chemicals at the same place that tests your water"; continued to go to Leslie's for the "free testing" over about a two week period, got three totally different opinions from three different employees. One did tell us the only thing we could do is drain water, the rest tried to get us to start going through this huge chemical regimen, then we ordered Taylor 2006C. During this time, was using granular CAL HYPO shock until we ran out, continued using the trichlor tabs but staff told us to dial those WAY back, close to "1" on the chlorinator setting (vs "5") and should only use 3 tabs max per week due to stabilizer and high CYA.
Leslie's test results in order of date we went in (period of two weeks 7/30 - 8/14)
FC 1.22, 7.37, 1.4, 0.25
TC 2.39, 11.57, 2.52, 0.72
pH 6.4, 6.3, 6.3, 6.5
TA 0 (adjusted), 0, 0, 0
Calcium 72, 79, 89, 92
CYA 137, 125, 167, 177
Iron 0.1, 0.1, 0.1, 0.1
Copper 3.1, 3.3, 3.1, 3
Phosphates 139, 186, 212, 203
TDS 600, 500, 800, 500
Our testing since we got the Taylor 2006C:
August 14
FC 0.8 (I know, I know!) This I believe due to dialing back the chlorinator from the 5 setting to the 1 setting and not replacing the tabs timely
CC 0.6
pH Less than 7.0, added 30 drops of base to get to 7.0
CYA over 100
TA 45
CH - not sure I'm testing this correctly, never really red to begin with, more of magenta/purple and never turned blue
Action: Added 8lbs of Soda Ash, continued using trichlor and I believe we had one more round of CAL HYPO shock
Trichlor tabs were empty, added 9 tabs to the chlorinator, set it at "2"
August 17
FC 4.0
CC 0.8
pH Less than 7.0, added 32 drops to get to 7.2
Action: Added 6 lbs of Soda Ash
August 18
pH less than 7.0, added 27 drops to get to 7.2
Action: Added 3-4 lbs of baking soda
August 19
FC 1.6
CC 0.8
TA 150 (darn, added too much baking soda)
pH less than 7.0, added 33 drops to get between 7.2 and 7.4, added 35 to get to 7.4
Action: Went and bought household bleach from Aldi (no stabilizer), 6% Added one jug (121 oz)
August 22
Checked trichlor tabs, still 4 left (used 5 in approx 1 week) - changed setting from "2" to "3" based on low FC numbers
FC 2.2
CC 0.6
pH under 7.0, 15 drops got it to 7.0, 20 got it to 7.2, 27 got it to 7.4, 35 got it to 7.6
CYA over 100
TA 130 (do you wait for the entire sample to turn red vs pink? And ignore a flash of red which disappears?)
CH - still can't figure it out, never really turned red, but did turn sort of pink. added 80 drops at 25mL and color was pinky purple but never turned blue
Action: Added 121 oz of 6% bleach; checked two hours later and FC was 4.8 and CC was 0.8
August 24
FC 4.6
CC 0.8
pH below 7.0, added 10 drops to get to 7.0, 25 drops to get to 7.4
TA 140-150 range (used concentrated method)
Action: Added two jugs (142 oz) of Aldi 6% bleach
Visual observations - pool is typically pretty clear although I feel like I may be seeing some green tints if I squint my eyes just so. Spouse says it's just time of day and sun coming through trees. Maybe I'm being paranoid. We added two jugs of bleach tonight because I don't want to get any lower chlorine and with CYA so high, my understanding is we should have FC higher than we do. Purchased two 4lb boxes of Borax, but haven't used them yet. Completely out of CAL HYPO "shock" and hadn't planned on buying any - trying to go the household bleach method?? I know the trichlor just makes our CYA worse, but paranoid to turn it back down or get rid of it until I can make sure I know how to maintain a high enough FC. The pool does not get a ton of use (just two of us, 3-4 times a week) and remains covered almost all the time except when swimming or directly after adding chemicals (tons of trees around pool including three birch trees constantly shedding leaves). Filter is set to auto run 11 hours a day during the day - we have been running it much more than that and overnight each time we add any chemicals. We backwashed our DE filter 3x in one sitting for a minute each time to try and get rid of water. Still learning maintenance and not even sure if we are supposed to do something else with the filter (such as adding DE powder or manual cleaning). There is fine light brown dust in the edges of the liner going to the deep end of the pool, I thought it was maybe DE but could be dirt or dead algae. We have been vacuuming once a week. We have the heater off. A few days ago saw what I believe to be algae around the inside of the skimmer - brushed it off.
I always thought I could manage a pool - grew up watching my Grandpa do his, and it was pretty easy looking. But we have been very frustrated. Trying to just enjoy it...but......
Any advice would be appreciated re: continue trichlor (we have tons) or not, if so - how much? Or just go to bleach (any idea how much we should be adding)? Should we go the Borax route for pH? Will we be able to replace water during either close or open (and preferably an early open in March to take advantage of cheaper water prices - $2/1000 gallons vs $13/1000 gallons. In Wichita, the price of water is significantly cheaper from Dec thru end of March.
Best regards and thank you in advance for any insight or recommendations. Please note that we are trying to avoid a huge pool drain, but that's probably going to have to happen at some point??
Us:
August 14
CC 0.6
CYA over 100
TA 45
August 17
FC 4.0
CC 0.8
August 18
August 19
FC 1.6
CC 0.8
August 22
FC 2.2
CC 0.6
CYA over 100
August 24
FC 4.6
CC 0.8
