- May 30, 2012
- 2,240
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
I have a set of stairs in my ABG.
Splash Easy Above Ground Pool Step - NE113
Not promoting that site, I forget where I bought them.
They have bases or skids that go on the bottom. Basically, the edge of the stairs are about two inches wide and the skids are about 4" and go under the bottom edge. They are held on with zip ties (as per the instructions)
Well, my zip ties snap after about a week. I assume it is a combination of sunlight, water chemistry, and movement of the stairs. I have tried all sorts of zip ties, UV stable, extra strong, and whatever else you can think of. They all snap.
So, two questions.
1) Are these bases even necessary? The instructions say to install them, but nothing like a warning saying "you must use the bases". I have the stairs on a pad already. It would be nice if they were an inch or two lower. As they are, the top step is just awash most of the time, It collects debris and does not really get a good flow going over it. Leaving the bases off would be a double win. No need for zip ties, and the stairs would be 2 inches lower.
2) If you have to use the bases, any ideas for something to hold them on that does not degrade and snap so quickly?
Thanks
So, two questions.
Thanks
