when doing the alkalinity test, i do it like normal, 25 ml mark, 2 drops of 7, swirl, 5 drops of 8, swirl and then 9 and swirl till turns red, but instead red at 13-14 drops turns light organge and stays there, i can put 10 more drops in, wont make dif, also maybe worth noting, when turns green not very dark green like in videos, ph is 7.6 but FC is very high due to shocking recently since had to partly drain and refill due to CYA being rly high, CYA is down to about 55 now, might do slight drain to get it to 40-45, but anyways any idea whats up with alkalinity test?
