- May 31, 2012
- 179
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
Can anyone recommend a good robot pool vac that does not climb the walls? Last vac that I had that climbed the walls wound up putting a hole in the pool liner at the bottom where the pool walls are bolted together. Apparently the pool installers did not put enough duct tape over the bolt heads and flat steel plate that the bolts go through. I have since repaired the leak and sold the robot on E-bay and am currently using a suction cleaner which goes through the filter. Unfortuntly this dirties the earth filter and I am looking for a robot vac that that collects the dirt.
