Our AGP appears to have a...unique?...construction.
This means:
So...am I understanding correctly here that to properly bond this pool, I'm going to need 36 lugs? 1 for each leg, 1 for each rail, and 4 equally spaced around the pool wall?
- The metal pool legs to not form a reliable connection to the pool wall. Due to paint, gaps, etc.[/*:m:3ei4088n]
- Atop the pool legs is a plastic bracket, to which the metal railing and metal "ring" around the top of the wall is attached.[/*:m:3ei4088n]
This means:
- None of the 16 railing pieces are "connected" to anything else.[/*:m:3ei4088n]
- None of the 16 legs are "connected" to anything else.[/*:m:3ei4088n]
- The pool wall isn't connected to legs or railings.[/*:m:3ei4088n]
