Thread: Iron in city water?
    Sep 2007
    Toronto
    106
    Iron in city water?
    I have been getting recurrent iron stain last summer, ascorbic acid treatment works but it can get quite expensive. I have an auto fill system and I suspect the iron is coming from the city tap water. I am thinking to install an inline cartridge filter, I can get filter down to 1 micron, will it help to remove metal from the water?
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    Mar 2007
    San Rafael, CA USA
    12,086
    Re: Iron in city water?
    No. It's not the particle size that matters -- iron is an ion about 1000 times smaller than what you can filter. You need a cationic exchange filter -- something that specifically removes heavy metals such as most water softeners (some specifically focus on removing iron).
    Guest
    Iron is usually removed by what is called a "green sand filter" which is an ion exchange resin with a high specificity for iron.
    Sep 2007
    Toronto
    106
    So I guess I won't install the filter.
    OH TWINS
