Mikemod. You are in the same spot as me, I'm just about a month further along than you in the process. I slammed and slammed as well and killed the algae, but just can't get the dead algae out of the pool, so it's clean, just milky all the time. The thing I can't figure out from postings on this board is if the shock levels should dissolve the dead algae completely or if you have to vacuum it out. I've been vacuuming for a month and it just blows back into the pool. I've vacuumed to waste and it just creeps back in. At this point I just swim like normal, though would also like to know "exactly how to get the dead algae out of the pool"?
it has been getting a bit clearer over the past month with DE and vacuuming, but I'm certain now it will take all season to get crystal clear. Keep at it, but just know if you slow down on the bleach, brushing or vacuuming, it can and will get out of control again.
Another thing that I just added recently which I believe is what is actually clearing it up is a skimmer sock. Cost me 5 dollars for a pack of 5 and it works wonders. I'd get this ASAP.
you can do this!
