Please refresh my memory - the AquaRite or Aqualogic cycles the voltage between positive and negative to keep the T-Cell plates clean, correct?
I think I have a problem with my board (?) that was replaced around 2 months out of warranty ago! I am showing correct volts and amps on the negative side when generating chlorine but on the positive side I am showing around 31V but zero amps always. I have the chlorinator set at 100% but it appears to only generate on the negative side. When I review the diagnostic menu and hit the plus or the minus to manually switch it to positive or negative voltage everything looks good on the negative side but positive just shows 31V no amps.
No errors on the display though so I am not sure if this is an issue and havent been able to find anything describing a similar problem.
