Results 1 to 10 of 10
Thread: Polaris cleaner bags, which one?
    Round Rock, TX
    529
    I have a 280 cleaner and need to buy a new bag.
    I see several different ones for sale, but don't really know the differences.
    Leaf bag - is it bigger?
    silt bag - finer?
    all purpose - ?
    zippered - does this mean the other ones don't have zippers?
    I like the bag I got with it fine, but would not mind a bigger one if possible. I'm assuming that I got the all purpose zippered (if that exists) as it does have a zipper on it. This bag has worked great, but is worn out.
    thanks,
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Re: Polaris cleaner bags, which one?
    Your Polaris came with a K-16 bag. The K-14 is finer (Sand-Silt bag). Same size, both with velcro closures. The All-Purpose bage is a K-13, and has a nylon zipper. All are essentially the same size, since oversizing would permit too much weight in the bag, and possibly affect the performance of the unit.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Apr 2008
    Central Texas
    326
    I use the zippered silt bag on mine, mostly because that is what it had when we bought the house. However, I do like that it doesn't leave anything visible behind on the bottom of the pool. I haven't had to vacuum the pool in the 2+ years that we've lived here. 8)
    I bought my last one on eBay for far less than the cost of one at the local pool store...
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Feb 2009
    35
    buy two zipper bags. regular mesh. Don't get the leaf or silt. Dry one bag will the other is cleaning. your bags will last you a while. But not long enough!
    Luke Pools
    caretaker of over 500,000 gallons of water weekly
    www.youtube.com/lukepoolservice
    el duderino's Avatar
    Jun 2008
    Austin, TX
    118
    Quote Originally Posted by lukepools
    Why?
    Care to elaborate on this comment?
    Our pool- (Completed March 2009)
    20k gallons, 38x15 Free Form Gunite (3.5'-8'), 26' Negative Edge and 7' Negative Edge spa with blower, Midnight Blue Diamondbrite, AquaLogic PS-8 control, Goldline Salt Chlorine Generator, 2x1.5hp Pentair 2 speed pumps, Pentair DE Filter, Pentair 400k BTU Heater, and BlackMaxPolaris 280 w/ Hayward booster pump, Pentair Prowler 920, DIY Stenner Chlorinator
    Round Rock, TX
    529
    Luke Pools
    This is what I did. It is much easier to clean the bag after it has dried.
    Jun 2008
    Austin, TX
    118
    I was referring specifically to the comment:
    "Don't get the leaf or silt."
    Feb 2009
    35
    Quote Originally Posted by el duderino
    Why?
    Leaf bag = doesn't have enough back pressure on the bag to fill it out. The bag isn't any bigger than the other bags.
    Silt bag = too thin, gets holes in it easily. I don't think they make it zippered.
    Gooserider's Avatar
    Feb 2009
    North Billerica, MA, USA, etc.
    211
    I haven't tried one of the Polaris bags with a zipper, but I have been somewhat unhappy with the velcro closure bags. The velcro tends to get crud in it and wear out so that it stops sealing tightly... If the bag doesn't seal tight, your cleaner turns into a dirt repositioner.
    The leaf and all purpose bags are pretty good, and work about the same, with the leaf bag being just a skosh bigger, but not enough to make a real difference. The silt bag is smaller, and also works well, but you need to watch it very closely in use - I had one brand new bag destroyed the first time I used it - we get a lot of sand and silt in our pool, not sure where it comes from, and this was early spring so we had a lot built up. I put the new silt bag on one evening, left the cleaner running overnight - came out the next morning, and found the Polaris laying on its side doing donuts around the bag... Needless to say the concrete pool bottom had eaten a BIG hole in it...
    Gooserider
    Free-form Inground gunnite pool, Estimated 16-17K gallons. New Pentair TR60 ClearPro 24" sand filter and Compupool CPSC-48 SWG, Hayward SP1607X10 Pump w/ 1HP motor, 1.5" plumbing, Polaris Pressure cleaner w/ booster pump. pool is more than 25 yrs old, less than 35. Not painted, deteriorating tile surround. I am paraplegic, get in/out of pool w/ S.R. SMITH PAL portable pool lift (significantly modified)
    Round Rock, TX
    529
    My original bag had a zipper, but it does not open the entire side of the bag, so I was always having trouble getting all the gunk out.
    I bought two velcro bags and just emptied one for the first time. Hmm, it presents a different issue. I find that after opening it, and dumping it, the velcro likes to close back on its self. I had to fold it open to get it to dump.
    As I bought two bags, I can let one drying and one cleaning. Emptying the dry bag made more difference that the closure type for me.
    I highly recommend two bags!
