Hello friends,
I am experiencing the following symptoms with my intelliflow pump:
After running the pump for 18 hours, the pump's basquet is almost empty. The pump is set to run at 750 rpms. Pump primes well but slowly the basket starts to drain and only small trickle comes out of the suction end. I know the volume of water sucking should not be a lot due to the 750 rpm speed but some how the pump is almost running in an empty water container. Through the glass container, I can see there is about 4 inches of water in it.
Please help,
G.
Pumpentair intelliflow.
underground copper pipe 1.5
above ground pipes 2.00 pvc.
pool type: 22k plaster with side spa kidney type
None salt water.
Two skimmers and two drains one drain in the pool and one in the spa.
pool location: Claremont California
Please help,
G.
None salt water.
