Hi All -
Newbie here . Have been reading forums with lots of interest and believe I've picked up the relevant info but want to confirm here.
Basically I have a Summer Escapes Freestanding/Easy Set (not pro series) 12' x 30" pool. Like most others I've found that the included RP600 pump/filter system is woefully inadequate. Therefore I want to upgrade to something like an Intex Krystal Clear Sand Filter pump either 1200gph or 2100gph.
This SE pool does not have the skimmer setup - it has the suction fitting / thru wall intake.
So my main question - can I change from the RP600 to this Intex Sand Filter setup? I want to avoid hole cutting and I believe I just need hose adapter fittings - I see some people keep the original filter/pump in place (obviously not using it) to avoid some connection problems?
Thanks in advance,
Darren
Houston, TX
Thanks in advance,
Darren
Houston, TX
