So... pool remodel, new pump (Jandy VS-FHP1.0), new plumbing, new water feature (Paramount Parascope).
Finally got the pump up and running yesterday, and it looks like the pressure gauge on the filter only goes up (to about 10ish) when I turn the valve to activate the water feature. Otherwise, it sits at zero (though, now that I think about it, I'm pretty sure I was able to bleed air out of the filter and have water come out when the water feature was off).
Already emailed my PB, but... Did they just screw up the plumbing? Is this normal? Unfortunately, I didn't think to take a picture of the plumbing setup, and now I'm at work. IIRC, the center pipe of the valve (Jandy No-Lube) goes to the filter inlet, but I don't really recall the rest.
