TF-100 w/XL option on order
Found 10% liquid chlorine at Rural king for 6.99/4 gal Bought 4 boxes.
Pool is an 18'x48" 10,000 gal AGP with a 50lb sand filter.
Current condition of pool is balanced water and I added start up doses of baquacil 3 weeks ago so the levels are low at the moment. We had the typical lifespan of the baquacil, first year was great, second ok, and the third was cloudy non stop. This is the 4th year and we have had enough.
The reason for the original use of the Baq was because of a chlorine sensitivity but due to research and this forum I believe that the issue is the the Chloramines not the FC so we are giving it a go.
Will take before/during/after conversion pictures.
I do have one question though, will the white water mold go away with the chlorine or will I still need to flock and vac? I am concerned as our water supply is very limited and it's hard even keeping up with splashout and evaporation. We don't really have a well, it is only an artesian spring that fills a 400 gallon holding tank overnight.
