CHLORINE TOO HIGH! My pool is 2 yrs old this month. I had an above ground pool for 13 yrs...no problem with in-line chlorinator/hard piped PVC +Nature 2. I couldn't keep enough chlorine in it. This in-ground pool is a different puppy! I can't get the chlorine level to go down! Beautiful. blue water, crystal clear, LOVE it...but these are my latest levels:
FAC=8
TAC=8
CH=99
CYA=99
TA-120
PH=7.2
COPPER=0
IRON=0
PHOSPHATES=100
TEMP=75
It has rained so much here in the last 6 months, that we drain water off the pool sometimes 3 times a week. I take my water to be tested, I add acid when needed, brush the pool weekly, run the cleaner weekly, I am a very hands on pool person...I don't understand the chlorine level in this pool. I do not shock it! The levels are too high. Just this week, I have had an outbreak of yellow algae....my first one in 2 years! I put yellow out in it, hoping that would bring the level down & kill the algae...didn't work on the chlorine! I know some of y'all don't like the chlorine tabs...what about using those Silk tabs? Help!!!
FAC=8
TAC=8
CH=99
CYA=99
TA-120
PH=7.2
COPPER=0
IRON=0
PHOSPHATES=100
TEMP=75
