Thread: Cracked Plate behind eyeball
    Sep 2007
    Guelph, Ontario, Canada
    60
    I believe I have a small leak in the pool as when I did the pail test, it looked like I was loosing about 1/2-3/4" of water in a 5 day period.
    While closing this year, when I removed the eyeball from the return lines, I noticed that all had cracks in the plate behind the eyeball where the screws attach it to the side walls.
    I have 3 returns, a side wall vacuum port, and a skimmer in the water system to the pool. I have drained the water below the skimmer and all plates. The returns and side vacuum port plates all have cracks.
    1) Can I replace these myself?
    2) Should I do it before now or wait until spring?
    3) I'm wondering about the seal around the skimmer plate. How do I remove the face plate around the skimmer to look at the seal where I assume screws attach it to the side wall?
    Additionally, I noticed that after draining below the returns that the liner above the water line
    has about 1/16-1/8" of air between the liner and the wall. Is this unusual?
    Carl Schnurr
    Pool: 96,000 litre, vinyl liner, 1 HP pump, sand filter, Aqua-rite SWG, Hayward e.vac, installed 2005
    Spa: La-Z-Boy 'Relieve', 1300 litre, acrylic, with ozonator, installed 2017
    Test Kit: Taylor 2005C
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Cracked Plate behind eyeball
    Carl, always a pleasure to 'see' you here - I just wish it was under more pleasant circumstances
    The return faceplates need to be replaced I believe that for Hayward faceplates the part # is SP 1408 -(?)
    You can replace them anytime you want but, when you do - don't overtighten the 4 screws!!! That's what led to this problem to begin with The screws should be 'snug' but you don't need an impact wrench to put them on :P
    BTW - I'd look for the leak elsewhere, cracked faceplates don't leak much
    [please see the article in Pool School on leaks here for some more info on finding a leak 8) ]
    Have a GREAT winter!!
    Luv& Luk
    -Ted
    Sep 2007
    60
    Thanks for the advice waste.
    Our pool was installed a 4 years ago, and the faceplates have never been messed with.
    Is there a gasket or seal I need to worry about?
    How do I remove the skimmer face plate without breaking it.
    It feels like if I fidget around with it, it will click off, but I'm not sure.
    As for the leak, now that I have the water below the ports, I'll continue the pail test.
    The water is mid 50s. Too cold to do any in pool leak detection.
    Carl Schnurr
