i have a 24 foot, 52 inch tall round above ground pool i would like to heat using solar panels. placing the panels next to the pump and filter is impractical due to the lack of sunshine in that area.i have a 10 foot high south facing patio roof which receives nearly the entire days sunlight. i would like to create a stand alone system that uses a seperate pump to circulate the water up to this roof, back to the pool. i can provide the electrical needs for the pump.what size or type pump do you recommend for the job.i have an extra quarter horse sump pump available but would that be too much power.would one of those one eighth horse utility pumps do the job.what type and brand of panel do you suggest. the roof is about 14 feet by 14 feet so i cant use 2 by 20 panels.any plumbing advice would be great,i am not a good plumber.i will make a quick-connect system so i can remove the pipe going up to the roof when not in use.it would be an eyesore for the wife. i have posted a picture of the proposed patio roof. thank you paul
