Hello Everyone,
As part of my pool remodel, I am automating the pool with a Jandy Aqualink RS6 PS. The Aqualink will be located in a Jandy Power Center sub-panel (6614). The pool automation will control two pumps, pool lights, landscape lighting, and possible two outlets. There are two ways I can GFCI the devices attached to the Power Center.
1. Put a 50A dual pole 240V GFCI breaker in the main panel, and then run power to the Power Center. That means that everything in the subpanel will be GFCI. This is the least expensive way. However, troubleshooting ground fault will be more difficult.
2. Put a 50A dual pole 240V non-GFCI breaker in the main panel. Then in the sub panel, use GFCI breakers for the equipment. This more expensive than the first option. But since each breaker is it's on GFCI, trouble shooting problems may be easier.
Based on those two options, which one would be a better option?
Thanks
Minh
Thanks
Minh
